Huawei Mate 20
Member2020
No need install launcher.. There is a app lock function in settings..
Hi, it is not that App Lock in the Security and Privacy section of Settings.
I refer to locking or pinning some apps in the multi-tasking/recent-opened list so that they don't get sweep away when I press the Trash icon.
Please advise.
Thank you all.
aa123aa123aa
Please advise.
Thank you all.
Just swipe the target app downwards and check if there's a lock icon at the top right corner!
xuan123
Please advise.
Thank you all.
Before you press the Trash sign, swipe to the particular app that you want to keep and swipe it down then you'll see a lock sign at the top right of the app screen. If you get what I'm trying to say?
Member2020
Hi, Thanks a lot for your assistance! :)
Hmmm... But i tested that when i press that Trash button those locked apps in the multi still gemulti-tasking list swept away... :(
Member2020
Oh okay, got it.
Thank you.
Horace Bin
Wonder if should wait for 20X or get the mate 20, seems rather good price now at those local stores selling around $800.
icetrap
Anyone gt the UAG screen? Thinking of getting a cheap transparent screen but thinking of spending more for an expensive hp with the UAG plasma screen.
lorettatay
I'm using the uag monarch
Sent from HUAWEI Mate 20 Pro Emerald Green using GAGT
dolbymkv
Hi all, attach herewith are some photos of comparison side-by-side of telco display set (left) vs my phone (right).
Same device, same screen panel, same display setting, and under same lighting condition but color tints are different and mine has green screen discolouration.
tenshinoir
Just got my phone replaced. Apparently my new set is batch 43 LG panal. Fingers cross hopefully no issues.
fishdundee
same, i guess the finger print area needs to be as center as possible. just now re-enroll thumb fp, works quite well.
I think the way to go for now, is to use the liquid screen protector.... potentially going to waste my second screen protector....
