Huawei Mate 20
plustwo
You sure the $2 - $3 quality good? As in the touch feel. Some of it like not smooth at all. Used liao not SHIOK!
But honestly, I think the reason people get hammered for TG is because they lazy to wait for orders to arrived for online order.
And besides, the phone price nowadays already like sky high, people still willingly buy mah.
Too cheap say not good. Too expensive people nag and wait for discount, if not say not worth it all that.
Sent from Xiaomi POCOPHONE F1 using GAGT
i am very sure they are all selling the exact same model even the $30 protector everyone here has been buying. i have been buying protector from ebay for all the phones i have changed in the past 3 years now. it takes max 7 days to arrive, about same time as when you get your phone.
RestInPepperoni
Yes just left from Red white. Tempered glass $30 is really good. Using with UAG Monarch. Touch is really smooth. Did perfectly. No Pop out.
Does it have like weird dots on the screen or is it very clear? i've seen this other one that has some weird dots all over the screen and the seller claimed it's to help it "stick".
Geros_Peters
Those with dot matrix on the tempered glass is the type where there is only adhesive on the edges types and not the full adhesive uv type.
sajokj
No dots. They stick it for you. Works well with UAG. Don't work with the free case came in the box from HW
rain_myth
Mine is mate 20 pro..
have this problem.. when i press the side bar for volume.. this floating bar on right should hide within seconds or hide when i press the screen.. but it didnt.. i have to open google chrome, rotate the screen for it to make it go away..
is this the setting problem or some bug on the fone? :eek:
can anyone help me? :s12:
rain_myth
You mean it stay there if you don't do anything?
Yes.. it didnt go away.
my wife is holding one..her goes away within seconds after she press the side volume button..
nt sure wat going on with my fone :eek:
i have to open google chrome or some file, rotate the screen .. only then it goes away
AyuReady
I kana once during driving.. Can't replicate it but the bar stays there. I reset to get rid...
kirium76
Anyone applied the loca glue full adhesive tempered galas from gwmobile at sim lim? Any feedback? Does the fingerprint scanner work after applied? They selling for $29 now.
Sent from Samsung SM-N950F using GAGT
tahoo
I tried to bring the phone for a swim in a water proof seal bag.... But it kept saying cannot cover the top of the screen ...and it entered eye touch disabled mode..
Anyone can recommend a good security setting to allow to unlock the phone
And what is touch disable mode?
jlekssp
the phone is waterproof, why so worry...i already washed my phone many times
AcEz874
I must say the M20 Pro battery is astounding, today fully charged i went out at 11am and came back now, i used it normally like receive phone calls and call my clients, send/receive WhatsApp messages and some fb viewing, i came back still left 62% now. FYI im running WQHD 3120 x 1440 daily.
RestInPepperoni
I see, so which type is better? I assume the full adhesive one. Question though is, what about removal if u have the full adhesive? If I crack the tempered glass and I want to replace it, is it possible or will it leave the glue stains on my original screen?
RestInPepperoni
If u want the bar to go away u can just tap ur screen (not on the bar) or like swipe it to the right. Sometimes mine goes away sometimes it doesnt, kind of random
RestInPepperoni
That is because ur case is covering it's proximity sensor, so the touch screen is disabled. This is usually to prevent butt calls, or basically random touches on ur screen in case it gets unlocked in ur pocket. If u want disable this, try pressing power and volume up button simultaneously
RestInPepperoni
Just want to correct this in case anyone destroys their phones.
Mate 20 pro is only IP 68 water *resistant* not waterproof. This means it can be immersed in up to 1.5m of water for up to 30 minutes. It's not completely water proof, or if u go in deeper water it might have issues. Huawei sells their own underwater cover for mate 20 but i think it's only available in China now.
Also just note that any water damage is not covered under any warranty so I suggest keeping it dry or try at ur own risk
