Huawei Mate 20
tomzire
My mate 20 pro also last 2 days 13hours. Non gamer but watch Youtube every night for about 1hr to 2hrs.
chenaz
I don't think it works.
Huawei quick charge technology is using their own tech. Is different from the UC green is quite standard for all other Brenda out there.
anybody using this Ugreen QC 3 charger with Huawei Mate 20 able to get quick charging (2 bolts). it is advertised as FCP compatible but I am unable to get the 2 bolts. only able to get it from my aukey qc 3.0 charger.
https://www.lazada.sg/products/ugre...mate-20etc-uk-plug-i103632291-s104702007.html (non referral)
p105ss
waiting for P30 to out and mate20Pro price to drop! :s22::s22::s22::s22: How much drop do you guys reckon it'll be?
Audiology93
Mate 20 does support USB PD and some QC3.0 for quick charging at 9v. Tested on my MacBook charger + xiaomi 45W laptop and charger Baseus 10000mah slim QC3.0 powerbank.
Sent from HUAWEI Mate 20 using GAGT
chenaz
But quick charge and super charge is 2 different thing. From your screen shows quick chsrge. Not super charge.if use original cable u should be able to see super charge .
Super charge is faster than quick charge
Audiology93
Yeah quick charging is not as fast as super charging as it can only go up to 18W but its easier to find a charger without FCP since it's Huawei's proprietary charging solution. Good to use as a spare charger in office lol.
limcc
If you want to get a charger that do it all(except VOOC/DASH) for phones, try this: PD/QC3.0 Dual port TypeC 36W. UK/SG 3pin plug or EU 2pin plug.
With EZbuy forwarder, <$2 below 1KG, the total cost is less than S$20. $14 + $$1.70 = $15.70.
Type A port output
Type C port output
Works for HTC10 with QC3.0, works for Mate 9/20/X/P20 Pro with SCP. but the Type A output is limted to 18W, thus the max curent is ~3.6A@5V. Still better than QC or FCP or PD cause these use >5V with max 3A current. higher voltage equal higher temp as the voltage conversion is internal.
fOreveRity
Need recommendation for tempered glass on m20pro. First I bought was side adhesive with the dots in middle of screen. Unable to use finger print. Second one bought in jb full adhesive but it got scratches n crack within first week..
Sent from HUAWEI LYA-L29 using GAGT
Watadoo
Bought mine from Mobile Hardware.
UV with no border.
Fingerprint unlocking not perfect though. Might be attributed from my sweaty palms
ZergRush
If want cheap and good get mate 20 pro
If desperately need change phone and don't mind pay then get P30 pro
If phone still can use and dont mind pay, wait for mate 30 pro.
P30 while good camera comes with lower spec screen and older chip. Mate 30 most probably come with same camera with all the other upgrades
