Huawei Mate 30 Series
progene
Precisely. Dont even knownwhat samsung is doing. Thats why feel like changing.
:s13:
So far any issues u all encountered after sideloading GMS?
do u all apply TG or film to the phone?
Use my raw. Only equipped my mate 30Pro with the free case.
Still deciding which to go. Tampered or those glue.
Sent from HUAWEI LIO-L29 using GAGT
progene
Side load also using lzplay?
So far, I saw 2 common method.
One via laptop, another via OTG thumb drive.
But end result is same. you get Google play store. It work just like any Android phone. Only as was some Bros say, some apps like MacDonald and Google Pay not working.
yongsoon80
Hi, I have a working gms installed. There's a new update recently. 10.0.0.154. is it safe to install? Will I lose my GMS?
KeYoKe
No issues other than the fact I cannot use 3rd party launchers ( only for tiong sets it seems ). I am using glass tgsp on my phone
Posted with the Sammy foldable phone via the HardwareZone Forums app
Most common issue is Google pay. Some apps like Netflix need use old version. Some apps like McDonalds can't use.
Thanks all for answering!
I can live without google pay, and netflix cos i nv use them at all
Main reason why i change is for camera n battery life ba. Whats the sot u all manage to achieve?
@technolust bro u using which TG? zeelot?
anyone can share the link to guide to install GMS? so many guides but not sure which is legit and working
haylui
So it is different from the lzplay apk source?
technolust
I using zealot glass yes. Battery life is not bad, similar to the p30p type of set
Been using for almost a month. Gpay is not essential for me and I dont Netflix, so the experience for me is optimal
Aikon
:s13:
You're evil bro....
I can feel the poison ☠️ slowly coursing through my veins... So close to my heart... Once strike I bought liao!
Already very tempted to sell off McLaren 😂
KeYoKe
moonSymph
screen on time is very good.. I'm using dark mode.. mid brightness 7hr+ iirc was running last cloudia lol...
moonSymph
do u have aod on? did u enable app launch for all app to system managed or u totally disable it? I notice if aod on and u place phone on a bright place the phone will be as though max brightness throughout and will use quite abit on power..
My battery drains quite fast. Any idea what's going on?
lorettatay
Only $3 plus from shopee. Nice and cheap.
Sent from HUAWEI Mate 30 Pro Purple using GAGT
