Jeremy1
- Jul 31, 2006
u mean the original charger n cable? if use others brand the charging slow only right, no super charge right
Yes, you won't get the super charge feature.
Local set all are dual sim i thinkAm thinking of getting this phone after my OP3 bricked couple of days ago..
https://www.m1.com.sg/personal/mobile/phones/details/huawei mate 9 gold
I saw that there are dual sim and single sim. Is the telco set single or dual sim?
Also just to check if Huawei got local svc centre? After my OP3 experience really want to find a phone with local svc support..
Im using
great! Whole day I didn't miss any WhatsApp notifications! This works!OK will try. Thank you
By default, those settings are turn on for chat appsgreat! Whole day I didn't miss any WhatsApp notifications! This works!
Change your habit, just charge whenever you can. There is no need and no point to wait till 30% to start charging.
My 2nd tempered glass screen protector cracked again...zzz.
Now thinking of going back to normal screen protector or just use without
Sent from HUAWEI MHA-L29 using GAGT
Got from small time shopWhere did u buy the tempered glass from? Did you drop ur phone or something knock it?
Buy from aliexpress lorMy 2nd tempered glass screen protector cracked again...zzz.
Step countguys wat is the running shoe icon with numbers on the locked screen?how u off it?
My carousell doesn't have notification as well.I am not getting alerts from Carousell on both P9 and Mate 9...
anyone else have the same issues?
there's a more direct way if you are taking a screenshot to share..
just hold down the home button, tap share, a screenshot will be taken without the overlay menu, select app to share
You can take screenshot too by holding volume down button and power button.Is this the only method to screenshot without the overlay?
Knock the screen twice using your Knuckle or press power and volume down button at the same time.Is this the only method to screenshot without the overlay?
