Huawei Mate 9
mosprockett
jtch74
Hi guys
I will be travelling to China soon and will be getting ceramic white mate 9 from there . May I check how to get Google play store working on the phone .
Appreciate if anyone could help me before placing an order in taobao. Thanks !
China version can works in singapore?
kEvinErd
Have. Just look for "Themes" in the app drawer.
Sent from HUAWEI MHA-L29 using GAGT
Wow.... That's a super cluttered status bar with more than half the status bar filled up. And you didn't even have any app notifications..
cwsamuel
Unfortunately no, I asked a couple of sellers in taobao, their reply is the same. Not able to work in Singapore.
Not sure anyone using China version in SG?
Why not? China rom should work in SG just fine.
I personally have used at least 2 China rom phones in SG, although not this mate 9. I do not see any reason why any China rom will not work in SG.
alphacool
I'm currently in m'sia, bought a Malaysian sim card and put it in my mate 9. It still recognises that sg is the real "home" and m'sia is roaming. Is there some network lock settings I need to change?
Supposedly you need to remove the SG SIM, leaving only the foreign SIM inside, then it will find the updated ROM.
Camping here for B158 reviews before I jump in.
123xyz
Hi,
any users in the B138 firmware. How is the battery life & any significant changes after the update? I am still on the original B110 version but contemplating whether to update due to battery life concerns
