Huawei Mate 9
shingo
Wah, thanks for this. Looking for something that can allow me to lock the screen without using floating dock. Those downloaded via playstore doesnt work as it requires pin number after scanning fingerprint
Can someone help advise how where to find this in 172?
Audris
Mine was updated to B172 a week ago and the battery noticeably became worse. Before the update, the battery life could last me more than a day but now it can barely last me a day and heats up. Tried switching off and on and deactivated background data for some apps but still the same. I realised for the past few days, the mobile data also keeps switching off on its own when phone was woken up. I have no battery saver app installed. What could be the issue?
KeYoKe
Clear google play services cache then monitor. If still same, suggest u to backup your data and do a factory reset
thorsten139
Hi bros.
Just got my phone yesterday.
Any idea on how to reduce the icon size on the homescreen without using a separate launcher?
Seems like a waste of space, the phone display is so big but the icons are humongous in size. =(
actually more like the space between each icon, the vertical space is huge but only house 5 icons
grover03
I factory reset after update. 7 hours sot no problem if moderate usage and no games
Sent from HUAWEI MHA-L29 using GAGT
KeYoKe
Hi bros.
Not possible
KeYoKe
Hmm not sure why i saw the charger and cable at huawei @ 313 somerset is 58 while some of u get it for 48.10
saltycoke
Sometime My phone seems to hang when I using FB. Then will auto restart FB again. Anyone got this issue?
1c3_5n0w
Hi bros.
the only way to do that is to adjust the dpi officially but itll make everything on your screen smaller, which means you can see more on the screen. settings > display > view mode > small
KeYoKe
Dont think this makes the icon nor the spacing between the icons smaller :s13:
IAmZTX
anyone know how to increase the size of the status bar?? All the battery icons, etc seems small
chinkt
VLC not responding the first time I used it after installing.
Have to close it after a while.
Hello_M0t0
Hi guys, need help here. I can't seem to connect my phone to Hisuite on my pc all the time. Always say non connected. Is there some settings i need to change?
Thanks in advance
