Huawei Mate 9
alex22
keyboard logo can be remove
1.click the icon on bottom right
2.select configure input method
3.disable huawei swype
my drawer mode has no problem, can you elaborate future whats the problem?
The keyboard logo below the enter key, on the navigation key bar.
I've disabled all other input methods and user only Google pinyin ime.
EDIT: it's Gboard which I can't disable. Option gray out in language n input.
Drawer mode:
Have to drag icon from drawer onto desktop in order to put into a folder.
Cannot multi select stuff from inside drawer at one go.
molecule
Yeah kind of miss the double tap function on my G4 and G2, can minimise the usage of the side button. But all is good.
I also used G2 in the past. Use the fingerprint unlock on M9. Its even faster and better and can link to other apps like dropbox.
Add a lockscreen widget on the homescreen for quick lock. Done - no need to use the physical button.
I still use the G2 as a backup phone so i can certainly attest that I dont miss the double tap one bit once u get used to it. :) in fact G2 double tap is slower as u need additonal step of PIN unlock if u set a PIN.
alex22
Sorry if i missed an earlier post, is there any way to see isit fast charge or normal charge?
SuperCharge i know can see 2x lightning symbol..
FastCharge is what symbol ar?
Normal charge is just 1 lightning rite?
2x large lightning = super
1 big 1 small = fast
1 big = norm.
I use other charger in office, 5V/2.4A = norm but acceptable.
alex22
Reason why I prefer pinpad + scramble is cos night time no one can take my fone n press to my finger n unlock.
You know what I mean?
alex22
Just saw. Original local M9 charger n cable is $58/set.
In china from Huawei direct is RMB$109
Omg
alex22
Where can buy? Taobao?
My link is official Huawei CN online store.
Still looking for just the Supercharge Cable alone…
Don't think any other "5A-capable" cables work like their proprietary cable.
