Huawei Mate 9
Shadow79
anyone here got good cable type C one to buy? where can buy?
thanks
If you intend to use the original charger for supercharging, you need a cable that support 5A current. Taobao sells a few compatible cables support 5A beside the original one.
RSKeisuke
you will need the original cable for supercharging (not fast charging), unless 3rd party cable makers add that 2 extra conductors, otherwise your only option is to buy from huawei
GReddy G9 RS
Just got my B188 but only managed to do a quick update instead of full download package which i always do. Actually what's the difference?
Sent from HUAWEI MHA-L29 using GAGT
GReddy G9 RS
JPadPro
Got the 188 update for SingTel.
looks like EMUI is now at 5.0.1 after the update
nologicboy
Actually did anyone notice the super charger on HuaWei's taobao site is only like 22SGD and comes with cable? Pretty cheap if you ask me.
chris1987
Hi Bros,
Do anyone know anywhere that can replace my cracked screen? I have utilized my free replacement at Huawei service centre before and am looking for an alternative.
Thanks in advance!
nannan82
Been using tis phone for many mth.. can say tis one of my fav to,date.. battery life no horse run and it fast too haha
