Huawei Mate 9
chyelimcc
Oreo update for Singapore Telco?
Hi, anybody updated to Oreo with Singapore Telco ?
I am with Singtel prepaid. No update.
RSKeisuke
try borrowing a foreign sim and check for update.
expired prepaid sim works too
i did the same. i am on singtel. singtel always slow as f*
andyhtc
Suspended
I'm on Circle.Life and I did not get the Oreo update too. It is probably rolled out region by region. By Jan 2018 we should be able to get it and more of the Oreo bugs would have been ironed out.
wherehouse
Dunno if it's the app or the os.
Qoo10 app doesn't load sometimes.
Live10 also.
Cimb app takes long to load
banana10
Hi,
Those who updated to 8.0, can you help me check whether there's 'LDAC' option under the developer settings? Should be related to bluetooth.
Thanks in Advance!
RSKeisuke
Hi,
Thanks in Advance!
banana10
Wats LDAC.?
It's a bluetooth codec, should be better than APTX-HD. Was only available on Sony phones to be used with Sony bluetooth headphones like the MDR1000X and the newer one.
Just read in another forum that LDAC is baked into Android O, so just wanted to check whether it's true or not.
lwandyh
Ah I see.. thanks for sharing.. so haf u updated to oreo?
meekiatah
not yet, still in office. Not sure if the SIM will trigger the update or not.
And I also need to backup the things in the private account ( ͡********* ͜ʖ ͡*********)
Maxis sim should trigger. I had the Hotlink card installed when it triggered system update. But I prefer to hold out first.
wherehouse
Live10 also.
Everything is back to normal after a while. I think it's the phone caching…
But still no double tap to wake, no way to set data usage counter monthly reset and countdown timer cannot manual input desired numerals.
kiawui
Facebook app got some issues too. When view photos posted by others, when you click on like the app will hang without any images. Need to back and then click on the image to go in and view again.
Sent from HUAWEI MHA-L29 using GAGT
lwandyh
I see.. technology too fast advance ardy.. some app still unable to catch up yet
