Huawei Mate 9
5408854088
Anyone got issues with grab? The map doesn't show but it says "google play services are updating". It was working previously. Currently on B188.
princewenle
Using this phone for almost 2 yrs and still remain strong.. quite headache
Should i renew and get the new phone or change to mysim plan without phone?
Sent from HUAWEI MHA-L29 using GAGT
Oinkize
Uninstall google play services. Then update it again. Mine was like this as well.
lwandyh
Convert to sim only plan better. More data to use & cheaper. Im using singtel sim only nw with mate 9
chris1987
:s12: I converted to Sim Only plan ever since i bought the Mate 9 too.
1.5 Years and still strong and snappy!
alex22
Anyone's stock Huawei weather widget not updating after fw upgrade to v368?
friedapple
can I ask if anyone experienced weird camera 'shutter sound' which will sound periodically even in silent mode? Not sure what is the issue, it has nothing to do with camera but every few hours will have a 'shutter sound' randomly and out of nowhere. :(
alex22
Nope not me
magixz
Can we use this?
No Logo Hybrid Double Dual SIM Card Micro SD Adapter for Android Extender 2 Nano Micro SIM Adapter For XIAOMI REDMI NOTE 3 4 3s
http://s.aliexpress.com/QRFBrmii
Sent from HUAWEI Mate 9 using GAGT
eyz
Can we use this?
you can DIY to slot 2 sim card and 1 msd card in the tray.
Garlics
Anyone here using NFC SIM? I am finding it failing me alot of times. Either I miss my train or I am stucked inside and I have to restart the phone.
Getting annoying
Try calling EZ-Link. Likely, you'll be advised to get it checked at a TransitLink ticket office. If the NFC SIM card isn't a recent one, it's probably faulty. You may exchange it for a new one with the telco for free.
