Huawei Matebook X Pro
plainsman
Been following this laptop keenly past month or so.
https://www.amazon.com/hz/reviews-r...R/ref=cm_cr_othr_mb_paging_btm_3?pageNumber=1
Alot of owners hv reported heat issues.. This laptop runs hot 40-50c surfing n 70 gaming...
We all know no.1 killer of computer parts is heat
This might just be deal breaker
Pls all try to look out for more resources or reviews online regarding this
Just sharing
Also, amazon link above has alot of folks who ordered almost 2 mths n hv yet to receive
katty91
Just sharing
those temperatures that u mentioned are quite normal temperatures..
and surprisingly good for an i7
not sure why u say a lot of users report heat problems as far as I see from the link that u have sent.. simple search of keyword like hot and heat. most of them are praising how laptop remained cool. only one review says that it does heat up once in awhile.
plainsman
I also hope to be wrong
Wish theres a display set can try it out physically
I think 2nd or 3rd review says theres
- coil whine
- fan is constantly on
- heat dissipation issues
- thermal design cld be better
Saw youtube reviews and was so wowed by all the good stuff. Any local owners pls share ur experiences too cheers
katty91
- coil whine
will review when i get my hands on my sets
youtube reviews are one of the reasons why i decided to buy 2 sets for myself and my hubby
dolby atmos sound and the 3k display screen are dope
plainsman
Tks! Yup screen looks so good. 13.9" in 13" form factor, v slim bezels and brightness 400+ nits. One thing i rly dislike is v dim displays
lorettatay
Dunno when ms will stock up on the i7 models.
lorettatay
should be late august but i do not dare to ship in on my own. later damage or battery can’t clear
Same as u get from that seller in carousell. Anything wrong I don't think he will refund.
tutonic
So he will help u to send back for warranty if anything happens ?
Unlikely that it's the case. You're simply paying extra to buy the export set locally, because you're having second thoughts about the delivery portion. If you don't really mind waiting on delivery and are brave enough, might as well just purchase directly through a forwarding service, like what others here have done.
watzup_ken
Just sharing
Heat is definitely going to be an issue with very thin laptops. In fact, the numbers you mentioned sounds better than expected. Is that referring to the laptop surface temps or the actual CPU temps? I suspect the laptop may also be transferring some heat to the chassis, which will cause the surface temps to be quite high.
Couple more things you will need to consider are, what is the ambient temp and where did the user put the laptop, i.e. is it on the bed where the vents are blocked. These things will not be mentioned by most, but will determine how hot the laptop will run. Try looking out for some video reviews.
