Huawei P30 Pro battery change
qwertzy
Hi, I understand official Huawei service centre will change battery for you for $50, but they insist upon a factory reset, which means all apps are cleansed. Do you have any idea why only Huawei insist on such a procedure (when iphones do not)?
If I change 3rd party, I wouldn't be sure they are going to use official battery.
Thanks.
selim
Thanks.
Instruction by goverment body to factory rest when I replaced Matt 10 battery
Milo-Dino
Thanks.
Well one thing is provide customers with the necessary privacy. You wouldn't want confidential documents, chats, photos being leaked just from a phone servicing.
Rather than deal with that, they just make every reset till nothing left.
I did the change and restored everything with a couple of hours from backup. Not a big issue la.
Yea, but why only Huawei, and does not apply to others?
Factory reset is necessary for Huawei. I did it last year with my old Huawei Nova 3i (battery swollen, replaced under waranty). I have decided not to replace the battery of my Huawei P20 since it is still usable and I am using it as a backup phone now -- moved to Realme X50 5G (bought at S$399 from Challenger).
Last time it was the same for Samsung (for my Samsung Galaxy S4 LTE+, for servicing, not replacing battery), not so sure now.
Apple does not do that, but they do warn you to backup the data before the batter replacement. I did the battery replacement for our iPhone 6S (early 2019) and iPhone X (recently).
Nickttmseller
Hi, anyone have any recommendation for change of battery beside Huawei Service Center? They totally have no stock for battery and have no estimated date of shipment arrival as well..
