Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
yhw22
I have received the EMUI 12 update today.
I got it a few days ago by forcing it to update. For those didn't rec it, can go MyHuawei to change to Hong Kong, then click Update in the MyHuawei. After update, you may change back to Singapore.
highsulphur
Any good reason to update?
A.r.S.e.N.i.C
Anyone knows how to not open notification as a floating window if you drag down the banner? Before the update, dragging the banner down will expand the notification instead of opening as a floating window. TIA!
Yuripa
Anyone tried doing battery replacement before? Did it affect the waterproofing?
I think more or less will be affected.
Service center glue is applied by man while factory manufactured is by machinery.
I've replaced my front screen and back cover on separate occasions. Since then whenever I wash my phone under water, there will be vapour droplets inside the camera lens.
But it will dry up on its own and I can use as per normal after that.
A.r.S.e.N.i.C
I see, thank you!
Johnteoh
Any problem restoring from backup after the battery replacement? Thinking of getting the battery for my P30 pro replace tomorrow.
