night mode 5 secs shutter speed.night photo
protune on
wb 3000k
iso 100
color flat
Anyone use GoPro for your car as a dash cam?How is it? Thought of buying it together with the suction cup
anyone here using gopole reach? can give review? example the impact when jumping down from cliff can cause the pole to loose?
int in getting the base as well. anyone has it? can have some review
thanks lot!!
too expensive for dash cam daily recording.
unless you are using it for your race days.
From what I saw, the price for a good dash cam costs around 200-300+ dollars.
http://www.lazada.sg/powerucc-panor...xmor-sensor-in-car-video-recorder-207208.html
http://www.blackvue.com.sg/
http://www.lazada.sg/blacksys-cammsys-bl-100-2ch-blackbox-camera-export-209473.html
Looking to get a GoPro. Any advise where I should get one?
I am using POSH Dash cam.
One of the best design I have seen.
Quality of the video is good and It is under $200.
Used to use blackvue but issues I did not know when the dash cam died while driving.
Some design of dash cam hung too low of the windscreen and imo it is ugly sight. You will face this issue too if you use any action camera.
With POSH dash cam, it stick flat to the windscreen and I can adjust the mounting and positioning to make sure I can always see the LED indicator and yet it is still hidden well behind the rear mirror.
Recently got mine from HN.
If you base on the pricing, the price is the same for the major retailers HN, Funan etc.
Ask other and see which retailer gives you the best service and buy from there.
Harvey norman![]()
gopro prices are controlled.ah. from what i've observed the base price of the gopro is pretty standard.
may i know where to get accessories that (i hope) are cheaper?![]()
if you buy from those non department stores, they may give you 10-50 discount.
accessories, PM me what you need.
