HWZ GoPro users
Shutterfly
Any recommendation on where I should buy the SD cards for GoPro? Or I should get direct from GoPro? :)
Shutterfly
Anyone managed to ever get to talk to any chat agent in their support page? Seems like the agents are forever busy. In this way, how to reach out to them for support?
derekliu
Anyone using 3rd party battery for Gopro? I realise my battery for Hero 5 seems to be faulty. It discharge within a day after charging full previous night. So thinking of getting 3rd party batteries instead
Sent from Samsung SM-N986B using GAGT
nwh_sg
my 3rd party batteries (Smatree) didn't last.. all became bloated after a year plus. They also didn't hold charge as well as the originals.
Having said that, I noticed the original one (hardly used) also became slightly bloated after 2 plus years.
monkeykong60
All batteries regardless being original or 3rd party will get bloated or shorter lifespan after intensive use or if not store properly
monkeykong60
Get those 3rd party batteries for Gopro 8, incase you may want to upgrade to gopro8 which uses the same batteries, but need to use decoded battery
hacktic
u get a cage and mount an LED on your gopro or you get the expensive gopro light mod addon.
No action camera is good in low light because their sensor size is small.
the best of low lights are the sony A7S
nwh_sg
do note that telemetry overlays are not supported in Quik Desktop for Hero 8 and 9. You got to use the phone app which is a nightmare. There is a 3rd party solution (got to pay for it).
