Call up them to check. Individual cell like couple of hundreds if i rem correctly.
https://www.hevshop.com/
Don't take the trouble to replace individual cells unless your battery bank is reasonable new.
Less than that. It depend on travel mode. Do take note Honda design is mild hybrid system vs Toyota design.
So far I think most user need to replace battery around 3.5 year. Ie in 10 years life span, you may need 2 replacement.
In a few vezel hybrid group chat, with some of the drivers using the car for uber/grab and having the car for 4 years with 5 digits mileage, all still good though.Less than that. It depend on travel mode. Do take note Honda design is mild hybrid system vs Toyota design.
All about the same price nowadays la $3k for brand new, cheaper if reconditioned/used (assuming you're driving a non luxury brand car)Anyone got lobang to change hybrid battery....used/oem....thanks for recommendation if any
Hi, see my other thread where I experienced the 'check hybrid system' message last weekend.
Car is approx 7+ years old, around 110k km on the meter. When I bought the car 2.5 years ago (second hand) I was getting around 700km on a full tank (40L tank). It has slowly declined and recently getting around 600km only.
Driving is 70 city/30 highway.
Prior to the last incident, I've noticed a loss of power: when you step on the gas, there's a slight lag and then it seems to kick in after a while. Also, the engine starts up more often to charge the battery, which dips to 1 bar more frequently (when I first got the car, it was almost always at 2 bars, then the engine would kick in to charge it back up).
I guess since I got the car at 5 years old, the battery has declined slightly over the past 2 years, but more evident the last 3-6 months.
I'm getting a battery replacement as it's under warranty from Borneo.
how to get the battery replacement from Borneo?
do they classified as normal wear and tear?
just got a used almost 8years old ct200h with 110kkm ( which is a hidden prius), i want to renew COE and give the car to my dad as his retirement car... so i need to replace its hybrid batteries
I don’t understand this question?
Prepare money and call them for an appointment to change battery. No ?
My bad. sorry, I didn’t read the earlier message.was quoting Gymrat76 : I'm getting a battery replacement as it's under warranty from Borneo.
Just wondering on what basis, we can use this warranty.
I understood the battery has 10 years warranty
HYBRID BATTERY WARRANTY
Lexus Hybrid Drive has an excellent track record of durability and reliability. To extend this quality assurance to you, Borneo Motors has introduced the industry’s first extended warranty for a hybrid battery. On top of the standard three-year warranty, there’s an additional seven-year warranty to give you greater peace of mind throughout your Lexus ownership.
Regardless of any changes in ownership, the Lexus hybrid battery will remain under warranty for 10 years* from it's original registration date under Borneo Motors.
*Applicable for vehicles registered from 7th June 2012.
There shall be no restrictions on the number of hybrid battery claims** from Year 1 to Year 10.
**Applicable for vehicles registered from 1st July 2018.
Just bring it in and ask them to diagnose. If your car falls within the 10 year warranty period and shows the signs of needing replacement, then they will replace for you under warranty. Only Borneo can give you the answer as it's case by case basis on how they judge a battery needs replacement. Are you having issues with the car that are battery related?how to get the battery replacement from Borneo?
Yeah it got replaced under warranty, then we sold the car hahaNo issue yet, maybe just the charge doesn't seems to hold too well. I will bring it to borneo soon then to let them diagnose.
thanks Gymrat76
did you finally replace the battery back then?
That is assuming you go back to Lexus AD to service the car right? The servicing will be expensive, compare to outside workshopwas quoting Gymrat76 : I'm getting a battery replacement as it's under warranty from Borneo.
They have to recoup the $ somewhere...That is assuming you go back to Lexus AD to service the car right? The servicing will be expensive, compare to outside workshop
