I need a recommendation
linkumpoot
Hello all!
When it comes to building a PC or buying a monitor, heck, even electronics, I'm an idiot.
I'm looking to buy a new monitor mainly for movies and gaming (not pro but I like to play FPS, D3, WoW etc).
My budget is about $500. Can someone please recommend me a very good monitor? Preferably 27" but if there's an extremely good 24", I'll go for it. Hopefully something that allows me to do dual/triple screen in future.
If it helps, I've got a Titan GPU.
Thanks in advance =)
Swiftbladez
Since you have a titan, might want to consider 1440p monitors. The only ones that fit your budget are the Korean monitors. No warranty though.
linkumpoot
What if I'm willing to take a step down. How about those 120Hz? Or if I up my budget to $600?
