i5 3470 help
deepblue_82
Hi, i am been using the i 3470 for a long time now, i am asking how can i enable to on board gfx? it has a intel 2500 but i tried to put in the hdmi but there is no signal can anyone help?
deepblue_82
and also i forgotten to add i know i remove my current gfx card and uninstall the drivers already
1) put back gfx card
2) go to bios set to onboard gfx
or
1) remove mobo battery 30mins to reset bios
2) default value for bios will be loaded your onboard should work
xonix
Check what is the motherboard model and go read the manual section BIOS.
You will know whether it's auto detect or have select manually.
deepblue_82
or
I have tried to set in the bios on the board but still does not work, ok maybe I need to read the manual
ZrE0_Cha0s
your manual should have an option to put either pcie or onboard 1st.
