royfrosty
- Jul 23, 2009
Hi guys, I got a mixture of answers pertaining to whether if my converted HTS on PC needs
a sound card to improve the sound quality or not. Some said yes and some said no. And each
has their reason to backup their claim. Well, I think there is no right or wrong answer here.
Basically, the bottomline is whether the money is well spent for a sound card with the quality
it produces or not. I'm quite curious to find out thinking that it doesn't cost much anyway.
Any advice for a compatible SC that costs around $200-300 to kill my itch?
I'm considering creative products, worth or not?
TIA
I think you are a bit confused here.
As long as you are connecting to a hts you will need either a hdmi, optical or coaxial digital output from your pc. Digital signals comes in binary 1 or 0. You cant physically change the bits and adjust to it.
A sound card is good for people whom wanna connect speakers direct using an analogue cable like rca 3.5mm cable etc.
