iNO3 4G LTE NON CAMERA
yoahyoyoyeo
unable to detect my ino3 on my computer? unable to install driver? any guys have this problem too?
I swap ports, swap cable, restart comp and phone. Nothing seems to work
WestGuy
Saw this on their Facebook:
Roger Lau
Yesterday at 8:15pm
Please be informed that a new software update (from v007 to v008) is out for iNO3 to fix mainly 2 things. 1. Sensitivity of touch. 2. Enable downloads of certain apps that were previously deemed not compatible. If the phone has not prompt you to do the update, you may also manually start the "WirelessUpdate" app in the all apps area and click "Detection of update" to download, install and update. Recommended that there should be at least 50% battery power to do the update to ensure successfully completing the update, as sudden power failure will result in software corruption. Although the update will not wipe-out the phone, as a precaution, it is highly suggested to do the necessary backup just in case.
Ran into some issues with setting up the Singtel data network on the ino 3. Figured it out after awhile.
Hopefully the steps below will help fellow users if they encounter network setup issues.
1) Go to Data Usage > 'Singtel' tab > Enable 'Mobile Data'
2) Go to More > Mobile Networks > Access Point Names > select the option 'IDEAS'.
By default, Mobile Data is not enabled, and the APN is set to 'Singtel Prepaid' .
Having the 'IDEAS' APN set as the default might provide a smoother experience for users.
Does anyone know how to do a screenshot on an Ino 3 ? I tried Vol Down + Power button, nothing happens.
Edit: Okay nvm, I just have to hold both buttons a little longer for the screeshot to work.
chiokcc
My one month old iNo3 died on Boxing day. Unable to power up after I swop SIM card. Went to iNo service centre this morning, and they changed the whole motherboard. So I have to re-install my apps, do the settings etc.
... sian ...
