Inserting new posts in between existing posts
Intrinion
Senior Moderator
Senior Moderator
Hello,
When you refer to “adding new posts between posts 1 and 6”
Are you referring to the analogy of say: inserting new rows in excel? If yes? - then I don’t think this is currently possible on the forum software since it is time based.
PikaPika33
High Honorary Member
This would be a very useful feature to add, for those ts who like to update their thread without choping post first :o
Later chop posts too much too fast tio ntuc points for spamming :(:crazy:
Mecisteus
Just edit, shift and merge contents of posts #1 to #6 into 5 posts.
1 post # will be empty and free.
Shion
Senior Mentor
Hello,
As Intrinion mentioned, it is not possible to insert new posts between old ones. :o
Thanks both :s12:
