Hi all!
I need a bit of advice here.
I'm 27 and I currently have
- Aviva hospital plan 2
- Great eastern Flexilife 20
Insured $100k for death
$50k for critical illness
$50k for Accidental cover
I have been looking at an early CI plan because I'm not covered for this? My parents said that Medisave will help though thus not really needed for an early CI plan?
Let's say if I want to get an early CI Plan.
I'm looking at AIA Triple care and my GE advisor has sent over a GE Critical Care plan. Or anyone has a better advise on other CI plans?
I read that the GE CC plan covers major cancer.
Does anyone know is cervical cancer included?
Thanks in advance
Hi Geraldine,
Aviva Hospital plan 2 covers Ward A in govt. hospitals.
Do note basic Pre and Post hopitalisation coverage is only up to 90 days.
Their premiums is currently the most expensive across the industry.
If you do not have any pre-existing conditions, I'd suggest a switch of insurer.
Great Eastern FlexiLife is a limited pay (20yrs) wholelife policy. Not sure how much premiums you are paying for it but the sum assured is inadequate (unless you could self-insure).
A general healthy amount to be insured is $500k Death, $500k TPD and $200k for CI.
Depends on how long the plan have been inforced or if you currently have been doing any form of investment yourself, you might want to decide whether to surrender the policy for a term plan that is much more cost-effective, or just simply top-up the amount of coverage with a Term plan alone. Premium roughly $1k+/- per year to get you adequately covered for death/tpd/ci.
Early CI in my opinion is not a must-have plan. Generally, someone who have been diagnosed with ECI may only need to go through some test and examinations, and if hospitalisation is necessary, your bills could be reimbursed from your shield plan.
Chances of loosing your job/income due to Early CI is also lower.
Unless you religiously go for annual check up, the chance of diagnosing a CI at it's early stage to make a claim is also low.
However, if you'd like to mitigate any form of risk, just-in-case, you can consider a $50k - $100k coverage. Any higher coverage would be ridiculously over-insured in my opionon.
While Medisave may be used to cover any potential medical expenses incurred by an early stage CI that may not be covered by a shield plan, getting a early CI plan might still make better sense from this perspective.
Cervical cancer if i'm not mistaken, are only covered by female plans such as PruSmart Lady and AIA Women of Wisdom. These are generally not covered under Early CI plans. Breast and cervical cancer are not considered as Major Cancers because they are generally not as deadly compared to lung or brain cancer. The key is to go annual or bi-annual checkups and get them discovered early and seek treatment accordingly.
I haven't came across the GE critical care plan. Just last week I was reviewing a client's policy and he had AIA Triple Critical Cover.
Compared to what AXA has, AIA TCC is expensive and not as good as it sounds.
You can share your GE critical care plan and I would look through the details for you if you like.
