iOS 14.0.1
boba_fett
quick tip, use the double or triple tap to activate safe scan.
I'm using double tap -> scan safe entry
triple tap -> check out
Fellowes
I use double tap for multi-tasking, triple task to drop the notification bar.
Safe entry I use singpass so no issue.
PongRareRare
1 questions - for the widgets, there is a very limited number of available widgets, right?
Not all widget can added into the smart stack, right?
Am i doing it wrong?
I am missing my Strait Times app in my iphone but it's available in my ipad.
Overall, I think smart stack is cool if they allow more widgets.
So long as size matches, you can stack them. I think, I haven found any that don’t stack. Anyway, it’s so limited. Just add them den manually put on top, they’ll combine
TrueBeliever_jh
Hmm how u do that? Can’t find on my iPhone :(
SingPass App -> Gear icon (top right) -> Siri voice commands -> SafeEntry
then add "Scan SafeEntry" and "SafeEntry Check-out"
these 2 items should appear inside Shortcuts~ :o
then add a Shortcuts widget~
ragnarok95
Senior Moderator
Senior Moderator
Sweeee thanks bro!!
crossair
The clock widget keeps getting de sync.
Such a simple thing but cannot be gotten right.
Matrock5
How do you guys find the performance of iOS 14. Seems abit sluggish on my ip X.
Halo green
You can also use double or triple tap to activate like volume up/down, lock phone, Siri and many more
Just need to tap the back of your phone, if I am not wrong this feature only available for iPhone X and above
I think he's asking how did he activate scan safe entry by double tapping and triple tapping checking out
punker
I want to tap and activate the safe entry lol 😅
ragnarok95
Senior Moderator
Senior Moderator
The clock widget. Show me cup, Sydney, tokyo, Paris for what sia. Can’t seems to replace them. :(
