Ipad 1 charging problem
sakratulmauts
Shows accessory not supported.....
Charger not faulty still can charge .....
At times can charge some time need to plug in out
Or on off before it charge
So whats the problem
maxheadroom
U using the original charger? I don't, that why mine charge halfway and need to power on and off, before it can continue to charge.
mac_mac
Hi, what OS you running? Highest supported is 5.0.1. Also base on experience if it shows accessory not supported means either your cable or the plug is not original......
skipper
not true,highest support is 5.1.1.
heng32
Replace another data cable. I used to have this problem but after changed a new data cable is working fine.
