iPhone 12 Pro / Pro Max camera cannot close focus
Matrock5
I tried after watching the YouTube video link you posted no such issue. I could even go very near to my pc mouse logo n text.
icyflame
llthim
I am using 12PM and I am facing the same issue as well. Tried to report this through apple support but they couldn't find issue from the hardware diagnosis. They requested me to go to the store to check on the phone.
icyflame
Both 12PM got this issue
12 pro focuses at very short distance, meaning no such issue
kruzeryo
Please update us if you go to Apple Store to check on your phone. Much appreciated your update. Thank you.
Snoweagle
Same thing here, not sure if it’s even an issue or because of the slightly larger sensor size.
nachtsid.er
It’s the sensor size, you notice at closer distance the depth of view plane is also thinner esp the longer lens ?
Posted from PCWX using Celcom
nachtsid.er
Short explanation , the larger the sensor the depth of view decreases ie the area in focus front and back of an object decreases . Try on a ruler and you can see for yourself.
This is also how the iPhone 12pm gets more pronounced bokeh aka background blur when taking portraits
icyflame
Probably so. Every lens have its own min focusing distance. What is weird is that people with iPhone 12 Pro used to have this problem but was “fixed” by iOS 14.2. This is from the macrumours discussion
ragnarok95
Senior Moderator
Senior Moderator
I don’t use wide for close up. I only use the tele for close up.
