Iphone 14Pro Max Running Hot
maxheadroom
Just wonder if just mine. But while charging & using at the same time, at the back of the phone is very hot.
Even without charging, the phone itself feel warm on using...
Is this normal?
*adiBOY
Is this normal?
It’s normal when you first restored the phone. iOS needs to do caching. After a couple of days will be fine.
mogita_
No need to worry. Just remember to get off hands when feeling burned. My iPhone does this all the time.
maxheadroom
Get a replacement IP14 Pro Max and this time do a iCloud restore, everything seems normal. And the battery life is great.
Recommend people who have issue with the set to change 1. Since you are paying these much...
1982-1994
They have stocks for replacement?
OkBuKeYi
icloud full restore?
OkBuKeYi
but every apple store out of stock for 14PM leh
maxheadroom
Usually when you unit there is a problem, within the refund period you can immediately got a replacement. I did a refund and purchase again.
So it not a gray box and diff serial number to it.
When I was MBS, there is already been 3 person having battery issue waiting for the exchange.
After 3 days of usage, morning charge 100%, with screen always on, heavy usage on whatapps & imsg, taking picture and GPS bus navigate, web browsing and Facebook.... consider moderate usage... iPhone 14pro max still hold the power of 53% at 7.30pm...
maxheadroom
Personally I will recommend you try the beta 2 ... And at the same time you can log the call with apple that you having issue and requesting a replacement. For now they don't have extra to make a replacement, so you might have to wait.
But at least you log the call
IceX
Mine only gets hot when playing game, is this normal?
