Iphone 5 Batt problem
exterminazn
iPhone 5 batt is very weak, 100% drain like within 4-5 hours, brought in nov.
Any solutions to solve this suck batt life?
maxheadroom
There if a discussion about this. Guest you didn't catch it.
The Facebook is draining the battery and it recommend you end the apps. Or turn off the chat.
If you upgrade to 6.1.3, and you restore from iCloud or backup, it best you do a iphone reset setting(not erasing the data). It found that some of the bookmark, Bluetooth setting seems to be the cause of it.
The major is the Facebook apps draining.
