iPhone 6 Plus 16G flash disk speed
gongroger
I am using 6 plus 16G and found some of the apps has bit delay (0.5 seconds sometimes) from the moment I press it to the moment it starts, when I tried to use the 6 plus 64G, it doesn't feel the same, it's more smooth. I run some of benchmark tools on both machines and found the mark for storage I/O is much different, if 16G can get 600 points, 64G then is roughly about 800 points. I wish to know if you guys are also using 16G, what is your I/O mark on your benchmark app? Please state the mark here and the benchmark app you are using, so that I can install the same app to tell if mine is the same as yours. Thanks
gongroger
Anyone can help ?
grey_fox
Really?? Flash gate now?
muddle
I assume it works like an ssd. Google how ssd works. Lower capacity ssd is slower than those higher ones. Something gotta do with parallelism.
Let's assume there are 2 nand chips for the 16gb model, whereas there are 16 chips for the 128gb model. The 128gb model can access data on those 16 chips at the same time, whereas it can only access 2 chips for the lower model.
gardiboy
Is the performance difference very significant?
gardiboy
TS, your score of 1700 - 1800, was it on the 16GB model?
Also, please share with us how obvious the speed difference was.
U used same config and backups for both phones?
gongroger
Not the same, two are totally different users phones. The feeling is like if you are about to open an app, and the app will be started not that fast if you compare with usual use. I just don understand how comes my I/O is that much different from others, maybe I shall see more replies and marks shared later on
gardiboy
Do the usual, a full restore from iTunes and re install all yr stuff. see if it improves.
gongroger
Did it and just installed Antutu and did the benchmark, the mark is still around 1700, that's why want to see how about others
EldonChew
P.S just curious if anyone knows the reads and writes of the NAND flash used?
DarkBlue
I believe also during the cost ordering of the NAND, the 16 64 128 are from different suppliers.
I think the 16GB Nands are shared with the 5C, 5S.
As for 64, 128 should be sourced from their new supplier.
gardiboy
Do u believe that the 16GB models are slower than the 64?
