evildoctor
- Mar 3, 2012
Hello Guys, I just gotten my iphone 6 plus and I noticed it lags when i want to go into the multi task menu. And also sometimes it lags too! Has anyone experienced it?
I set up as a new iphone! iOS 8.1.1
Reset your iPhone may help... Hold sleep/wake up button together home button until Apple logo...
Thanks for the help! But it doesn't seem to solve this lag. It's lag and stutter like when I want to switch app, I need to double press my home button. Then when it exit the app and go into the multi menu, it like lag/stutter exiting the app. I tried on all app. And I check my the log , it has a bug 167 TCCService. Should I exhange my phone 1 for 1 since it's less than 7 days?
Ensure settings are the below.
Settings / General / Accessibility
Home Click Speed - Default
Accessibility shortcut - Off
Yeah the settings never change. I on reduce motion and it's seems a lot better! Does that mean my phone has something wrong?
By default after a fresh reset with no apps open, you should not see any lag
Probably because your 6 plus is a TLC hdd. Unstable.
Even with apps open it should not even lag
Have you tried restoring your phone?
Yeah tried restoring already! But it still happens. Like 7/10.
