iPhone 6 PSAJ Case
Ian
PSAJ coating will peel off. This is discussed since iphone 5 time and i mentioned before. White matte, black matte, clear, smoke all will peel off to reveal the base clear casing. It's after all, just a coating.
I am not so concern about the peeling. I buy the PSAJ to protect my phone, not to look nice on it. :)
Not for me.
Especially those coating stick to my screen surface and kinda hard to remove it unless using scotchtape or hard rub to clear it.
Bro.... paid $49 for its premium product which doesn't last is not a good product especially if it's "faulty" within few months of usage.
metamofia89
Mine is from NuBox.
Paid for $49.
Very happy with its tight fit and slim design.
Only last for 2 Month so with that amount I paid for doesn't warrant a good review from me.
Well i guess Apple should look into their version of PSAJ then.
ragnarok95
Senior Moderator
Senior Moderator
Not for me.
Hmm, i don't think the coating peeling sticks to your screen right?
It is in no way faulty when even with the coating peeling, it still protect your phone. But of cos, it wont look so nice anymore.
There are better casing out there, cheaper too. End of the day, buy what you can afford and like. Btw, i have 3 PSAJ. One clear matte, one matte black and one force clear. The clear is in my drawer, the matte already have peeling on the edge and scratches at the back. The matte black also have slight peeling on the edge too. I am not too concern. As long as it keep my phone safe.
Vadher
Mine started to peel only after about 2 years. I think you should avoid cleaning it with solvents etc.
On my 2nd PSAJ for iPhone 6 now. The first cracked at the corner because it was not properly removed. Got to be careful.
