iPhone 6s Smart Battery Case
tec_geek
Apple has just released a battery case today and it's retailing for US$99 or S$148.
Description from Apple's Website:
Product Information
Overview
The Smart Battery Case is engineered specifically for iPhone 6s and iPhone 6, to give you even longer battery life and protection. The soft microfibre lining on the inside helps protect your iPhone, while the soft elastomer hinge design makes it easy to put the case on and take it off again. On the outside, the silky, soft-touch finish of the silicone exterior feels great in your hand.
Charge your iPhone and battery case simultaneously for increased talk time up to 25 hours, Internet use up to 18 hours on LTE, and even longer audio and video playback.* With the Smart Battery Case on, the intelligent battery status is displayed on the iPhone Lock screen and in Notification Centre, so you know exactly how much charge you have left.
The battery case supports Lightning accessories, such as the Lightning to USB Cable (included with your iPhone) and works with the iPhone Lightning Dock (sold separately).
Choose from two complementary colours:
- Charcoal Grey
- White
http://www.apple.com/sg/shop/product/MGQL2AM/A/iphone-6s-smart-battery-case-charcoal-grey
PetPet
Moderator
Moderator
I double checked the dates.
Nope not 1st April :s13:
MoyoCase
this looks worst than other aftermarket battery cases out there....
Cant beleive this is an APple product....More like CHina product ......
szeli
walao I thought this was some joke. e case looks :s22::eek:
stupidog
saw some comments that the white one will stuck with lints from ur pocket after taking out.
and good luck to those wear denim jeans. white sure koyak
