iPhone Auto Keep Reboot
spoon
My bro 6 also keep rebooting every 20sec,
Problem “solved” as what was told here set the date to dec 1.
3hubb3r
turn off phone notification would solve the problem temporary
bersaLobangSG
Am I the only one not affected?
11.1.2
I am not affected as well.
11.1.2
Things that puzzled me is...
Straits time reported “Mr Aung, a Singapore Permanent Resident who is from Myanmar, told ST that he woke up around 6am on Saturday and realised that his iPhone 6 plus had downloaded the 11.1.2 software update.”
Isn’t 11.1.2 out Super Long ago? 😐 iPhone do not self install updates unless you do a reset.
Qingrong
What does this recurring local notifications means?
A notification which is meant as a reminder which will keep repeating at fixed interval. And this reminder is not pushed from remote but exist locally on your phone.
sql0604
Turn off all notifications will temp soft the problem till Apple issue a fix.
Do not try to change date.
I have this problem early morning till noon now ok.
Jirachi
Just update to iOS 11.2 now. That should fix it.
