iPhone Charging using IPad Charger
jason910
I just want to check, earlier I was using the iPad Air 2 charger to charge my iPhone 6 plus I waited till it showed 100% and I off if unplug and took it out. After which I realise instead of 100% it showed 88% only and my phone was very hot. Anyone can advice me? Thanks
ipadxcell
Drain your iPhone batt till off then charge to 100% again. Report back ok
jason910
I was actually at my old house and there was no iPhone charger Except for e iPad Air charger thus for emergency I used it. Other wise I won't even use it at all.
Just wanna check if any Bros have any rational to my case. Thks
*adiBOY
Nope. The iPad charger can charge the iPhone perfectly. It will also charge up the battery of iPhone 6 faster.
Snoweagle
Been using my iPad mini 2's 10W charger to charge up my 6+ all the time including my previous 5s, no issues at all.
ipadxcell
Like other bros said. iPad charger is ok and faster too. Do what I said to calibrate your battery.
jason910
I know and have read what other Bros said and I have been calibrating my batt once or twice a month(drop to 0% and charge it) I'm just curious or puzzled why after charging it using a iPad charger for the first time, it shows 100% but when I plug it out it drop or showed 88%.
Kaylin
dont need the ipad charger actually. i use the usb wall socket and one of the ports is 2A and it charges both ipad n iphone pretty quickly.
EldonChew
It's the battery protecting itself by discharging and charging up later.
