Iphone Duo cases/accessories
vengence_angels
Did not see any good stand for iPhone Duo. 3d printed a stand instead for my iPhone Duo. Case with hinges can fit.
Can share the 3d print file?
argentinafa
Wow impressive bro. 3D printed yourself this stand. So the hole slot can accommodate APP, and the small AW charger can take turns to charge both AW and APP.
VodkaPear
Where to get UNIQ case? Was trying to look for it but then hav to fly. Tokyo can go where find nice case ar?
Deceased
Temporary until better ones! So far this TG should be able to fit most cases.
Just tried the Torras TG that is for the apple case, it’s similar to this amazingthing TG size so if not using apple case, it will be too small for other case like this speck case.
Oh well, back to Hoda.
argentinafa
I also think your Hoda size is the best so far bro. You took off your previous Hoda to try Torras. Now back to Hoda again it’s the same previous one or a new piece of Hoda sp from the box?
Deceased
Ya the Hoda quality and size so far is the best but don’t have installer tray.
Need to get new one lol sian.😂
disastrous
Seems like got 2 variant of case friendly screen protectors - one can fit Apple official ones but will be cut too small for other type of cases, then one more type that is cut slightly smaller that will fit most cases other than the Apple ones..
anizee
For those of you using cases with hinge protection, do you hear a click when you open / close the case? Not sure if the sound is scratching the hinge
