iPhone shuts down at 80% battery
ProJwJw
Hi, my phone shuts down by itself at 80% battery life and is unable to start again until I plug it into a charger. The phone then can be used again but may randomly shuts down again. Any solution?
rdreamer
Recalibrate the battery level first?
How old is the phone battery? Maybe it is just worn out (usually after 2 years) and needs to be replaced.
jq75
which model?
at 80%???
how long did it take to reach 80% from 100%?
paul02
Sounds like the capacity of your battery is in decline after years of usage. I believe your actual battery capacity is less than 20% (which is why your phone shuts off at 80%)
If you have AppleCare, you might be able to get your battery replaced. This is quite common.
szeli
if u have a Mac u can use coconut battery tool to check e batt cycles left in yr phone. chances r e batt worn out liao...
