iPhone13/Mini/Pro/Pro Max Accessories Showcase Thread
manofsorrows
Tried the highly raved mous 4.0 and had some complains: vol buttons kinda stiff and the back is prone to oil smudges even for the Aramid fibre.
The caudabe sheath is much better and it’s also cheaper. Actually I have the ringke onyx and it feels similar to the sheath except it has no MagSafe. Unfortunately I need the MagSafe feature else I would have stick to the ringke case.
Mind sharing where did you get this from and damage ? are the buttons clickly ?
leon0079
from caudabe singapore via shopee at $49 (only 3 colors available unlike the iphone 12 gen)
Yes the buttons are definitely more clicky than mous in my opinion.
Even though its a tpu case but the fitting is superb; you don't get those loose fitting at all.
Happy with this case.
if you dont need magsafe i would recommend ringke onyx as its very similar
i_am_fatimah
last year's onyx for the iphone 12 was bad. the fitting was loose at the top and bottom, you can literally push the phone up and down with the case on
this year for 13 is it the case as well? cos i saw youtube video also bit loose for some people :s22:
caudabe sheath for 12 wasnt tight as well, the sides also bit loose and the buttons are stiff, for 13 got improvement?
Charlie_Zhan
jus put on the Baseus Privacy TGSP, not bad at all
looks good.. i added it to my taobao card but in the end i removed it and decided to order the privacy TGSP from torras instead.. last time i tried torras TGSP and i liked it better than baseus ones.. and the ones from torras has metal grille for the earpiece.
stupidog
swee la
and whats that sticker haha, your hwz namecard ah
one day i got nth to do , was playing with my thermal printer...so printed my own avatar dp lolol
anyway, i dun really like the texture at the back of the pitaka case.
it feels like spigen matte texture to me.
edited : case taken.
manofsorrows
i like the rough texture at the back though... yes i defo need the magsafe.
anthonygreenisreal
I got the Ringke Onyx for the iPhone 12 last year and my biggest gripe is paint on the silver button easily flake off and then it’s actually just a beige looking plastic. They might as well use the same blue colour as the case. Coz the exposed white part makes it looks ugly.
BlueBull
Very good fit, no loose sides at all, just like my sheath for my 11ProMax. I didnt use the 12 ProMax so dont know about the loose fit situation. Dropped my 11 ProMax many times in the Sheath and not damaged at all.
stupidog
is the magnet strong with the attached magsafe wallet ? got stronger than original apple leather case ?
HZYiLong
OtterBox Symmetry+ does really have some strong magnets, I had to use some effort to remove it from the MagSafe charger 🙃
manofsorrows
@manofsorrows is the magsafe magnet stronger than apple leather case ?
I looking for a case that has stronger magnet leh.
the pikata magEz pro quite strong , but too bad i dun like the back feel of the case.
eh stupidog bro,
no leh i wouldnt say stronger than apple's. still sufficient enough to not drop, in car mounts. i tried on a friend's car mount before because he was particular about it when going over humps.
that being said, im eyeing the caudabe sheath case now. itchy liao. kinda like the back of the case. chor chor one. hahaaa
