iPhone13/Mini/Pro/Pro Max Accessories Showcase Thread
Lex1989
I guess you’ll love the iPhone except for YouTube Vanced. Ads will be there for you unless you don’t use app, use the safari with Adblock instead.
I'm waiting for WhatsApp to be able to interchange between IOS and Android.
Btw if i use gmail for my whatsapp backup, if jump over to ios, need to create new account or can retain gmail? lol
manofsorrows
Just got my okonz screen prots from 11.11 stash. the matt screen pro is damn good sia. no holes at the faceid sensors.. love it. i forgot which bro reco but thank you.
Charlie_Zhan
just use youtube premium $1.60 a month :D
Read HWZ Forum Rules!
mahcosg
love my 13 mini, battery life is even better than s20 ultra with 5000mah battery capacity.
WakaaWakaa
Anybody using an iPhone 12/13 Mini, can review?
Coming from Android, will i like the phone?
If you like your phone to just work smoothly without having to do much, then iOS has that edge. Feature wise there’ll be pros and cons as one changes from Android to iOS and vice versa.
I think it’s difficult to compare the Mini with Android phones since there isn’t really anything comparable in the Android category.
I’ve used the 12 Mini and now the 13 Mini. While not a necessary upgrade, the improvements in the 13 Mini build on what is already quite a good phone in the 12 IMO if you like compact phones.
Lex1989
You are right,
But i have like 10gb backup on my whatsapp, how to transfer?
Thank you for your feedback!
WakaaWakaa
You are right,
https://support.apple.com/en-sg/HT201196
I think now both systems allow for transfer to each other. When you first set up the iPhone there’ll be the option to transfer from Android. In theory should transfer everything.
But I can’t speak for this because I’ve only done iPhone to Android. Maybe someone else can shed some light on this. Naturally, don’t reset your phone until you’ve confirmed everything has been transferred.
night87
Bros, is Applecare worth getting for 13 Pro Max ? I keep having the "i am going to drop it " feeling. waiting for my spigen wallet CS to come and re-case lol.
anthonygreenisreal
not worth it if you the type who uses all round protection and/or someone who changes phone every year-ish.
It's worth if if you like to use your phone bare, got history of dropping phone all the time.
paul02
Speedy / Light weight / Compact / Things are simple / YouTube Vanced / Constant Update etc..
I notice iPhone 12/13 Mini is even smaller then Pixel 4a, thinking should i give it a try..
If you have the know-how, try sideloading uYou with AltStore.
I get all the features of YouTube Premium and more for free this way.
manofsorrows
i feeel have to get. even though if change phone every year.. i get a peace of mind if any **** happens, its still covered and a minimal cost. its up to you. you can go alab to get it at a 10% discount.
banana10
just got the pitaka magez pro.
feels way lighter than my previous case.
and the magnet is crazy strong
night87
Thanks bros, I dropped mine a few times, but my SPigen Armour wallet CS priotected it quite well hahah. Will check out at Alabs for the discount.
frizee
Anyone has good experience with any of the Privacy glass? Been wanting to try Baseus though..
Tried those $2-$3 ones and it seems to degrade the resolution a little :(
