iPhone14/Plus/Pro/Pro Max Accessories Thread
*adiBOY
Apple Leather case in the past used to be very high quality but since the iPhone 12 series, the quality of the leather case has deteriorated significantly. The leather now is just one super thin layer, even screen protector film is thicker.
Jirachi
Very sad indeed. Maybe consider getting the Nomad one :(
frizee
Are you guys going for Baseus glass this time? :D
Shopee selling 2Pc at $7.99 (clear).
hereiam7788
You make it sound promising. Because I want to order an Apple Leather case and the delivery is 14th. I hope I definitely can get it by 15th night before I bring the case down to collect the iPhone.
Actually u should just buy on the spot the case is not in lack of stocks.
hereiam7788
For those looking forward for "Apple Leather casing" - please beware that there quality has drop significantly from Iphone 12 series leather casing onwards. What I mean by drop significantly is that, the case will start to have black discolored patches around it. it looks ugly like hell. The side will peel off. This is coming from me who has been using leather case bought from apple for 2 years (I complained to apple and they switch it once for me for free and the problem came back after a year again). Suggest reconsider your choice and go for silicon instead. If not, go for leather from other brands.
If you dont believe me, you can youtube and see the effects after people have used for quite awhile.
I will go for silicon instead. If the quality of the silicon case is same as iPhone 13 pro I think it is acceptable.
Deceased
Gonna go with imos sapphire glass this year but unlikely will arrive before my phone so got to temporarily get another glass first.
Ye_Rongtian
Anyone planning to whack Shellrus sapphire screen protector at over $110 a piece?
That's US$110 not SGD$110, which is simply overpriced given that they came from the same factory with 2 other sapphire screen protector brands, which are selling for half price.
