iPhone14/Plus/Pro/Pro Max Accessories Thread
KeYoKe
I initially using these type of individual lens protector by okonz. Used a few weeks realized dust trap between the gaps very hard to clean, always have to use a small paint brush to brush off the dirt. End up removing them & applied a one-piece lens protector. Personally not a pro photographer, so can't really tell the difference in photo quality.
But one thing to note if you use such individual lens protectors, it'll be a pita to remove them. If you managed to remove them, there will be glue residues that are extremely hard to wipe away. I used quite a bit of alcohol wipes to remove them. (Not a good experience.) YMMV
Same thoughts. I also using 1 piece after the exact same situation u been through on indicidual lens protector
Remove is easy... Just a tip, use dental floss and cut the adhesive like u are flossing your teeth, the lens protector will come off after that. It is the cleaning of the residue that is :s22:
Ye_Rongtian
I just use the blunt end of pen knife blade slide between the gap and twist. It will pop right off.
elvintay07
Suspended
Have u tested whether it really push out 100w? I tried with the first port on MacBook Air using Apple usb c cable only getting 65w. Didn’t charge other devices at the same time.
Confirm no. My 65W ugreen can’t even charge my Lenovo laptop (65W)
Computeron
Carvan fivver.
Synthetic one, though.
I was very satisfied with my initial case with slide camera cover by Nillkin, so I replaced it with this.
The design this time lower the chances of forgetting to close back the cover 🤭
that gap between aramid fiber n the plastic... that thine line.. will it have dust? my rebel g4 will loh..
noobiee
Caudabe sheath with ugreen one piece lens protector, in case anyone wanna do the same and worry cannot fit.
我要买GTR
Carvan fivver.
Huh? The camera cover hang out like that when you taking photos? Sibeh weird leh :ROFLMAO:
