Rubick
- Jun 1, 2011
Rhinoshield ho eh.Walieu u also come n add oil![]()
Dont hoot will regret
Thanks bro, but the sandmarc camera module area has a metal frame to fit their lens and has a mount there so not sure if I am using lens protector, will the case still fit properly or not.Im using andar, can fit for andar though. Mine is the one piece kind...
I saw their advert on IG, I didn't know as well.Never heard of this brand till recently when they releasing titanium band for Apple Watch only![]()
I regret buying so expensive but already ordered, speedpost is supposed to deliver it by today but till now 638pm no sound no picYeah man.. For $44 i might not hoot it haha.. Heng i hooted $27
Check mailbox broI regret buying so expensive but already ordered, speedpost is supposed to deliver it by today but till now 638pm no sound no pic
Then better dont take risk bro...Thanks bro, but the sandmarc camera module area has a metal frame to fit their lens and has a mount there so not sure if I am using lens protector, will the case still fit properly or not.
Oh speed post not deliver to doorstep one ah ?Check mailbox bro
Yeah bro cos plus shipping and all around 80 bucksThen better dont take risk bro...
Depends bro. Most likely in mailbox cos mine deliver to mailboxOh speed post not deliver to doorstep one ah ?
They will put small item to mailboxOh speed post not deliver to doorstep one ah ?
Came.back from jog, saw package at my doorstep.Depends bro. Most likely in mailbox cos mine deliver to mailbox
Check out CasefactorieAnyone knows any physical shops selling Caudabe Sheath for 14 Pro?![]()
Msg-ed them but unfortunately OOSCheck out Casefactorie
Or maybe buy few cases and change daily before get hold of SheathBuy first think later!![]()
Should have on Lazada?Msg-ed them but unfortunately OOS
Or maybe buy few cases and change daily before get hold of Sheath![]()
Hahaha told u⦠best case for me so far⦠in loving it the mostReceived my catalyst case from taobao.
Really feels like my original one![]()
Can swap between my synthesis and this. The on hand feel still caudabe better.Hahaha told u⦠best case for me so far⦠in loving it the most
