iPhone14/Plus/Pro/Pro Max Accessories Thread
Op_Valkyrie
Just arrived!!
Op_Valkyrie
Si bei fast. Wah u using the belkin 3 in 1 charger too? How is it ah?
Side note: nice yamaha hs8 btw :s13:
I have two belkin 3in1, this one in the background is the gen 1 I bought around 1yr ago without AW fast charge. The other model the flat one with AW fast charge I put in office. Both models are good and I haven’t experience over heating etc… 😊
side note: it’s hs5 actually, coupled with hs8s and dac.
KeYoKe
Thanks for your input bro! guess its time to get the 3 in 1 to declutter some mess in my charging area :s13:
Nice audio set up there!
can tempered glass for iphone 13 pro max be used on iphone 14 pro max?
should be able to. screen size is the same
hereiam7788
that's good. then no worry of finding cheap tempered glass then.
Op_Valkyrie
Looks great! But my main gripe with leather case is it seems impractical to clean. Unlike my TPU case can just wash with soap and water. How do you clean yours?
Thanks, I don clean… cause changing every year mah… leather case once season the color and feel very nice one. If cleared case harder to maintain I feel… dust and Yellowish issue.
derkaiser94
I just like to wipe my phone/case with wet wipes everyday. If not like got bacteria leh. You don’t do that with leather case?
I had the leather case for my previous but the so called patina just looks like black grime.
ragnarok95
Senior Moderator
Senior Moderator
Guys remember to buy side protection to protect that lightning port! Current 12/13 pro max version will work! You just need to cut out that lightning port portion!
KeYoKe
+1 on the dust.... See the dust inside the case spoil look of the phone very gao wei :s13:
KeYoKe
bedlamite
I think it was from the 11 onwards where Apple applied this coating on their leather cases where it would never patina properly. I have the saddle brown for my 12 which seemed to just never age, then when the coating eventually broke down (which took a few months), you’d see blackened edges. Which is gross. I have a nomad case as well and that got some nice wear after only a few days, absolute world of difference there.
arcturuz
my spigen tg and ultra hybrid just arrive from amazon...next day delivery lol
KeYoKe
Thanks going to hoot and keep.
Got easy way of applying. Remove the sticker, then poke your lightning connector through the sticker first, then plug it to your phone, stick the protector down and voila..... Dont use the metal prong they provide to stick, a slight alignment will make the charging cable a bit more difficult to plug in
Op_Valkyrie
You very OCD, I’m sure not everyone here clean their case on a daily basis. Haha
Correct, patina on some leather will be nice and natural looking… some ppl don like cos it’s like spots over the leather.
