- Mar 9, 2004
What’s the diff between this 2? Looks same.. mine is the alignmaster
Got border and no border.
But same size? HmmGot border and no border.
Glas.tR Alignmaster is full coverage with thin black borders, Glas.tR EZ Fit is full clear non full coverage i think. Pls correct me if im wrong.What’s the diff between this 2? Looks same.. mine is the alignmaster
Where u get so good lobangI think so. Slightly smaller i believe. For S$23 now for 2 pieces, cant complain.![]()
I shared a few times liao. From amazon sg. Cheaper than in Shopee and Lazada.Where u get so good lobang. I bought Ultra Hybrid clear magfit version with Glas.tR Alignmaster(2pcs) from shopee. Hope I will like it. My first time using magsafe case..
Later I just gonna paste the screen protector as soon as I take out the phone from the box.
Think can skip the wiping of the screen?
Its good. Can keep changingFirst time hoot Belkin screen protector from Apple Store.
My Spigen TG. Nope not reuse from 13. The indent is barely there. it's longer and shorter than the 13 series.
There should be no cut out. U using the alignment tool? There should be an indicator showing top.no need to wipe if don’t have dust or dirt on screen
I got my screen protector from spigen and ink casing from apple liao
the spigen like no notch cut out for no-borders version. Is that correct or I hold the thing upside down?
Dont need. If wan jus use dust remover sticker to stick a bit before pasting the screen protectorLater I just gonna paste the screen protector as soon as I take out the phone from the box.
The indent should be very very minimum for this yr design.no need to wipe if don’t have dust or dirt on screen
Means what ah?Its good. Can keep changing![]()
Belkin TG comes with 2 yrs warranty.Means what ah?
