iPhone14/Plus/Pro/Pro Max Accessories Thread
OkBuKeYi
Regularly changing case will eventually scratch the phone.
Because they will be small dust or micro debris. The hard surface of the case will also scrap the phone's side when you snap the case on
if there's a dust beneath my screen protector will it cause my screen kena hairline scratches?
manofsorrows
yea learnt my lesson. used to always change and swop casing between caudabe sheath when day to day and then to quadlock when riding... the quadlock is darn tight to take out but yet its sturdy when mounted on the mount. shall stick to quadlock and not take out unless absolutely necessary.
Andykaka
just received my ESR casing, build quite sturdy and the magsafe is damn strong, even stronger than apple's magsafe casing.
zXioNGz
guys just checking if anyone buys casing for the Apple battery pack? Feels quite fragile like APP2 lol
我要买GTR
I bought this. Might or might not use it depending on how much bulk it is.
zXioNGz
You haven’t receive your battery pack ah bro? I also saw this cheap cheap at taobao, this one really people comment no use also turn yellow after 1 month 😂
ragnarok95
Senior Moderator
Senior Moderator
yes you are right, i used spigen for my 12 pro so when i bought 14 pro, i change to belkin ultra glass instead.
The Belkin ultra glass perform worse than the Spigen Glas.tr from one of the link i showed here. But it's a 2020/21 video. Of cos one can argue that since then Belkin have made improvement on the glass. That can be said the same for the Spigen too.
The Belkin Ultra glass is good because as long as you keep your receipt you can walk in and get a new one. Or just spend 30% of what you pay and get a Spigen TP which is as good as the Belkin. You get 2 pieces too.
ragnarok95
Senior Moderator
Senior Moderator
really bad luck although apple using lazada to sell their stuff. if bought from apple store can just return. if lazada apple, have to deal with lazada.
They are Authorized Reseller. There is a diff.
我要买GTR
Received alr but no time to open yet lol.
If really usable turn yellow just buy new lol so cheap only 😂
OkBuKeYi
No it won't. I have been using Spigen and Okonz TG since 11PM. Both brands are smooth. I played a lot of genshin in my phone, so if it's lag, it will affect my gameplay.
I was prev using okonz then i itchy hand go change to spigen and instant regret.
anw im gg back using okonz
okonz so far i like
Andykaka
I stick Amazingthing matte as per redwhite mobile recommendation. Been using it on my 13/14 PM, damn solid SP
ragnarok95
Senior Moderator
Senior Moderator
okonz so far i like
I use Okonz because Spigen removed the all clear TG for the previous gen. So for 12PM and 13PM, i switch between Okonz and Spigen. Now that Spigen has all clear TG (without black border), i use back Spigen. So far very happy with it. No lag, smooth and sharp and clear.
