iPhone14/Plus/Pro/Pro Max Accessories Thread
cherryboom
thinking of buying lens protector, thinking of buying those 1 piece type to cover the whole thing or 3 pcs type to cover only the lens. is it even worth it at all and will it create more lens flare?
KeYoKe
It will definitely cause lens flare. Those separate 3 piece type will have lesser lens flare compared to those 1 piece type, but the camera base isnt protected, i have friends that also scratched the camera base despite pasting the 3 piece type
我要买GTR
Rip my spigen TG :ROFLMAO: dropped by accident.
Ye_Rongtian
My 14PM in Mous Limitless 5.0 case feel lighter than 13PM in Mous Limitless 4.0 :s13: Must be the new softer tpu and warmer backplate.
bedlamite
i still thinking wan to to buy systhesis anot.
or the ringke onyx dark grey
Had an Onyx for the 12, it was a perfectly fine case. Nothing to complain about for 20 bucks. It looks like they’ve added grippy sides to the Onyx for the 14s, which should make a good case even better. Caudabe is the more atas option and the Sheath I had was grippier all-around, compared to the Onyx. The side lips were a little loose, so fit and finish was a bit disappointing, especially for a case that cost 2x the Onyx.
ragnarok95
Senior Moderator
Senior Moderator
Should buy the Belkin TG. Then today you can walk in and change a new one.
Computeron
I dont like the synthesis camera portion... I find it fugly
hahha i find it intertesing instead... if removed that "factor", its just like a nomal case liao.. not worth the $59..
if like that u said, then i buy onyx first liao.... have to order from korea... dark grey not in sg.
