netzach
My TB order just came yesterday!
Then, my Sis happened to have time to set-up her iP15PM yesterday as well. The moment she saw the dusts trapped on the edged of the Spigen Glas.tR EZ Fit screen protector, she told me to remove it!
I helped to paste the Smart Devil Dust-Free Corning Screen Protector for her. I must say, Smart Devil do make some great screen protector! The edges are beveled down, it prevent dusts from being trapped. The coverage is edge-to-edge with iPhone's glass. Despite being edge-to-edge, there was no issue with putting on the CASETiFY Impact MagSafe case.
Imo, I can feel the differences between regular glass and Corning Glass, it feels more robust and premium.
Thanks
@wwh5210
for sharing this brand!
true that.
passed by push carts selling the Spigen … and saw the person kept re-sticking.
wouldn’t recommend Spigen
Read HWZ Forum Rules!
netzach
apologies, but would it be possible to share the link for the smart devil TG to me here too?
on phone now henc hard to find the page
thanks in advance and have a nice weekend ahead.
galvin
true that.
Means that person simply no skill. Been using Spigen tempered glasses for years even before they included a frame for easy application. Now with a frame, it's even easier!
A pity that Spigen bundles their tempered glasses in a 2 pack nowadays because 1 tempered glass can last me 1 year before i sell off my iPhone annually.
gonna hoot new phone. any matte cases to recommend? I got sweaty palms v annoying...
Caudabe sheath is one that comes to my mind. any others?
ipadblack
uGreen vs LionShield screen protector which is better? Or any other reccomendstion?
Also any camera protector reccomendation for PM? Am looking at LionShield luxe series protector.
wwh5210
My TB order just came yesterday! 🎉
Then, my Sis happened to have time to set-up her iP15PM yesterday as well. The moment she saw the dusts trapped on the edged of the Spigen Glas.tR EZ Fit screen protector, she told me to remove it! 🤣
Thanks @wwh5210 for sharing this brand! 🙏🏻
You are welcome. In fact, the cost for the mobile accessories such as case or screen protector are extremely low. The actual cost those OEM screen protector on the physical stores are as low as $0.50-$1 whereas they sell you at $9.90. For me, I only get any "branded" screen protector between $5-$8 per piece and paste it myself every 3 months. I clean my screen with 70% alcohol daily so the oleophobic coating wears out easily.
kashix
Which selection you hooted uh? for the Smartdevil? can Sic! Thank you, thinking of getting 1 to replace my spigen.
|XcElLeNcE|
Are the Mous limitless and Caudabe Sheath/Synthesis equal in terms of drop protection ?
Mous definitely has much better drop protection due to the sides being much thicker than Caudabe case.
how come no1 here using zeelot solidsleek tg? haha.
I’m using Zeelot 3D glass.🙋‍♂️
This fiber version got sound one right when u squeeze the sides?
Nope. Tried squeezing with the case on the phone no sound leh.
Rubick
If price no issue. Mous limitless is more protective.
But my old Mous limitless carbon fibre case, the back will peel off.
so left the bare carbon fibre there. Not sure if new one will be the same
cloudystar
Spigen Thin Fit, Benks ArmorPro, SmartDevil Kevlar Case, Smartish Gripmunk :D
If you have more budget then PITAKA MagEZ, Nomad Rugged Case, Mous Limitless etc. :cool:
discoburg
The cheaper the better. Periodically change them also don’t feel heart pain.
Kusanagi
using pitaka magez pro for my ip13 pro, very happy with it
just to add, i was using the mous before that, but i found it to be too slippery, the pitaka is slimmer too compared to mous
now might try out transparent case instead once my set is here
