我要买GTR
- Jul 30, 2020
YasWah. U Westie?
YasWah. U Westie?
Steady. Me 2
https://iphonestudio.app/Anybody remember there was this website you can toggle between different colours of pro models, different colours of silicone , leather cases and even magsafe wallet.
to see the colour combination. I remember the models started with 12 pro and 13 pro and so on.
Any idea where is the website. Thanks
Y so???My sheath case arrived. Guess I’ll be getting the Spigen C1 case in the end.
Wow caudabe still not stiff?I like cases that have stiffer sides.
The Spigen Thin Fit im using now is stiffer. Hopefully the C1 case will also be.Wow caudabe still not stiff?
U get those hard plastic case can liao
Wait my one come liao i see how flexible this year one is.The Spigen Thin Fit im using now is stiffer. Hopefully the C1 case will also be.
The sheath sides flexes as per the Youtube review video I saw and was shared here previously. Magnet also weak!
Yeah I liked the apple leather case for the iPhone 13 Pro Max. The stiffness that is.Wait my one come liao i see how flexible this year one is.
Mine still waiting for production.
nomad rugged case is stiff. But really feels more bulky
Maybe you should have gotten the Synthesis instead of the Sheath. Synthesis is much stiffer and I think even more than the Spigen Thin fit. You need to really use strength to pull the sides.I like cases that have stiffer sides.
Was recommended by a few in here to get the sheath so just ordered without looking at the others from Caudabe.Maybe you should have gotten the Synthesis instead of the Sheath. Synthesis is much stiffer and I think even more than the Spigen Thin fit. You need to really use strength to pull the sides.
Any stiffer is those rigid hard cases or aramid fiber ones liao![]()
I like the side of synthesis. More grippy hahaWas recommended by a few in here to get the sheath so just ordered without looking at the others from Caudabe.
Was considering the pitaka aramid and Mous case as well.
Should have bought that thenI like the side of synthesis. More grippy haha
why ah?anyone here using uniq casing with smartdevil corning screen protector?
Synthesis side grippy back smoother.Should have bought that then![]()
Haha me not too into cases. My 'poisons' are other stuffs.Synthesis side grippy back smoother.
Sheath is all around that roughy feel
Is it? Some random guy in here was telling me it's really stiff.Wat?The side of the sheath been flexing since iPhone 6 case?
