discoburg
Can’t believe it but Anker power bank is much cheaper in Parco shibuya than shopee SG.
iosnewbie
Does Made for MagSafe chargers display their firmware and serial number info in the IP15PM running iOS 17.2.1 ?
I just bought a Momax MFM charger and according to an online review, the charger’s info should appear in General > About, under Carrier Lock. But I don’t see this info in my IP15PM even after I removed my case.
phayze
My belkin boostcharge have the information about the magsafe including serial number and model number.
iosnewbie
I have the Belkin Boost Charge Pro 3 in 1 and also don’t show any info. Am I looking at the wrong place (Settings > General > About ) , or do I need to enable a specific setting?
phayze
I find it in the same place as what u say. I never do anything. It just will show up. Using apple magsafe battery pack will also show up.
discoburg
galvin
Is lifting around the edges of tempered glass screen protector to be expected?
I ordered 2 different tempered glass protector recently, a cheapo <$1 one from aliexpress and noticed that the entire edge of the screen protector is lifted due to the rounded screen.
then i ordered from from Torras which seems well received and noticed that the edge of the glass is lifted as well. I followed the instructions and used the plastic orange rig to sit the screen protector. :(
Never experienced any lifting before. Been using Spigen tempered glass for years
Computeron
is urs no black boarder?
to my understanding not black boarder is not full screen cover... will have air around.
I dunno about other ppl.
to temp solve ur problem.. apply oil around it... every now n then.
