mikeeeey
Currently have on the Pitaka Pro Case. I think it looks rather good
can the grip be on for wireless charging? or have to remove the grip
UchihaSasuke
UchihaSasuke
Ugreen clear case is cheap and good. Covers the whole thing Including the camera area got MagSafe magnet on It. Can get for less than $10 during sales period.
Is this a hard or soft casing? Personally prefer hard one but those area that need to be 'soft' will be soft, not really sure how to describe it :D
https://shopee.sg/OtterBox-iPhone-1...se-Authentic-Original-i.422474232.23349659207
i using the clear version for my 15pro
but i dont like the slippery feel so i using my MOFT leather case :D
How is it? hard or soft, able to withstand drop from pocket length?
Adam80
otterbox>
soft sides(TPU)
backing hard
cloudystar
Caudabe synthesis use less then 6 months.
Standard problem for this years’ Synthesis owners.. Caudabe doesn’t have a solution for it and their replacements are all the same.. Magnets are too strong and they overpower the sticky glue.
One way is prevent is to attach the phone to a MagSafe charger before trying to remove the case 😂😂
discoburg
Threw the case away already. Wanted to clean the phone after staying in the case for a few months. Got a shock when I saw the magnetic ring attached to the back of the phone.
argentinafa
Can check if this case will potentially scratch the phone if taking in and out ?
I had the same worry and ocd-ness as you, prior to buying this case.
But rest assured, my blue Ti have not seen any scratches at all ever since taking in and out 3x already.
This case is only suitable if you have the super careful characteristic character, in handling your phone. If you’re those frequent dropper of phones kind like my wife or daughter, then better avoid this Pitaka.
