shikoto
Anyone has any recommendations for wireless chargers that are not magsafe? My kumgong ass bought the wrong Spigen clear case with no magsafe. Paiseh if question sounds retarded, it's my first iPhone.
Computeron
Mine is crazy so I went ahead and ordered an edge-to-edge type from Flolab (~$55SGD).
I think is normal... if edge to edge... ur sp will get lifted up by cases...
now u pray ur $55 won't get lifted...
xtwis7
FYI for those using or consider using Spigen's Glastr Ez Fit, it's a dust magnet on the sides.
I didn’t have good experience with past versions of spigen. Not full coverage and yet still pretty expensive for a SP.
paul02
ralliart12 said it earlier, "any SP that doesn’t go all the way to the edge will have this issue"
Anyway I use my phone naked, so this is not an issue.
xtwis7
$21-$23 for 2 pieces expensive uh?
I think they were more expensive back then. Nowadays more and more brands coming in. If I'm not wrong, glastr series has been known to be far from edge to edge type so for people who will find the excessive lint a eyesore, best to avoid it.
